Got my boat out from storage and now the trim is not working up or down. Batteries are brand new. All i was getting at first was a click sound when hitting the trim switch either from the front of the boat, the throttle, or the rear trim switch. Opened the case and only the top selenoid was clicking. I have replaced both selenoids now and still a no go. But the bottom one i replaced is now clicking. I tried tapping on the trim pump motor and still a no go. Also did a rapid clicking of the trim switch to try and wake things up with no luck. I am not sure what else to look for or do. Any suggestions? I have attached some pictures of what i am seeing. The little round thing, i have no idea what that is that is mounted on the outside of the lower unit, the wire runs to the back trim switch. The enclosed device by my starter batter i believe to be the relay? And i found a small hose that is just hanging and not connected at the other end by anything?
