18 hp fastwin
kaashlock
Just got an Evinrude 1968 18 hp fastwin Ser# 18802. She starts on second or third pull but wont run long. What should I do to her . Pumps water like a new one, great compression and sounds good. should I tear into the carb and rebuild it first or start with the coils maybe . Just wanted some advice.
Thanks,
Kenny
david_r
Re: 18 hp fastwin
check and see if you get a good blue spark at 3/8"-7/16" and check condition of the plugs.
if spark is good i would clean/rebuild the carb.
there is an thread on cleaning and a thread on adjustments in the frequently askede questions.
i have a '68 18hp evinrude and you can almost point at it sand it will start.
jbjennings
Re: 18 hp fastwin
I'd also try taking the fuel line off the carb and seeing if the fuel pump is pulsing fuel when you try to crank it. Definitely check spark with a tester and if good, rebuild your carb and set your idle jet properly.
JBJ
Bob_VT
Re: 18 hp fastwin
Fastwin Carbs are easy to rebuild. I would first check the gasket under the carb ....... make sure its tight...... you could have a leak.
If not I would rebuild the carbs AND do the electronics.
I am running a 1967 Fastwin 18 great motor :)
