18 HP Fule Line
Hi all,
I'm in the process of rebuilding the fuel system on a 61 Johnson FDL-15 including all new fuel lines.
The lines I removed from the fuel filter assembly to the fuel pump, and from the fuel pump to the carburetor all appear to be 1/8" ID.
Is this the correct size line for this engine?
Thanks.
F_R
No, it is 5/32", OMC/BRP number 0772571. I have used 3/16" from local Advance Auto Parts store, and it worked just fine.
Thanks F_R.
I thought the lines I removed looked small for the application.
Also thanks for the heads up on the 3/16" line.
It may be what I end up using with new clamps.
