Re: 18 HP gas leak
No, the manifold does not have any efect on the fuel pump. The pump must be pulling fuel from the tank or it would not run. If it only leaks when running, I would think the leak must be upstream of the pump. If it was down stream of the pump it would suck air rather than fuel. Look real close at the line from the pump to the carb and the carb itself.
