I have a 1966 18hp Evinrude 2cyl (18602). I am curious if anyone knows of any solutions to try for my problem. The motor usually starts great but thats where the greatness stops. I am having alot of knocking and sputtering at low RPM. I have adjusted the lean/rich setting on the front of the motor but it seems like it dosent do anything. Also, when I give it some gas i have to pull the choke out to keep it from dying. Once the choke is out it runs alot better and I can get to where I need to go...just not in a hurry because when i give it full throttle it seems like it is throttling back on me. This gets worse as the motor gets warmed up. I have changed the plugs and the water pump is newer, I dont think overheating is the problem. Does it sound like a Carb rebuild is in order or is there some kind of adjustment on the motor that I dont know about? Or could my problem be unrelated to fuel?<br /><br />Thanks
