18xd bent prop shaft
kingsnakejr
If you spin the prop shaft on my 18xd merc you can tell the shaft is bent.
Although there is no noticeable vibration in WOT and l/u gear lube is clear with no metal or water present. I can't afford a $300 prop shaft. A machine shop could straighten the shaft but the heat process to straighten it will make it weak and could be easily bent again. Would I be unwise to run it until an obvious problem arises?
Laddies
Banned
Re: 18xd bent prop shaft
We have a local hydralic shop that cold straightens them all the time, with no problems. It was cold whem it got bent wasn't it.
tredragon
I think my prop shaft is bent too (I see the same kinda wobble that kingsnakejr sees). I was wondering if I needed to address this as well... ie. what kind of further damage can be caused by this?
