19-6 boat has trouble out of hole
i have a 1991 ski boat with a 4.3 Mercruiser, it has a 3 blade 19P prop. I can only go 35 MPH at about 3600 RPM, wondering if i change to a 17P prop, will it help, and if i add the whale tail to the outdrive(or if someone can tell me the correct name for the attactiment, so i dont look like a dumb *** asking a shop for it that woould be great) any info would be great
pinecrestwoods
Re: 19-6 boat has trouble out of hole
I think I can hear the calculators clicking away. :rolleyes:
Without any fancy analysis.... your "35mph" at 3600 rpm doesn't seem bad. I would think that's a very comfortable cruising speed. Remember, you've still got 800 or a shade more rpm. Or.... on second thought, did you mean to say 4600rpm (WideOpenThrottle)? If you're maxing at "35mph" you could prop for a tad more speed, BUT your post title says "trouble out of the hole." Which is it?.... are you looking for more "get up and go" or more "top end"?
Also, a boat speedometer is a mere suggestion of how fast you are truly going.
Also also- what boat are we talking about, specifically?
pinecrestwoods
:redface:
Okay, Bubba, your interpretation makes more sense than mine. I just got all excited to post something, and didn't think it through.... I'm sure you understand.
Are there any other symptoms or behavioral changes?
Did it used to go faster?
Ayuh,.... You'll get over it,.... ;) Someday...:rolleyes:
Ayuh,...When was the last time this tub was given a Full, Complete Tune Up,+ Service,..??
Btw,... EFI or Carbed,..?? Which Carb,..??
What Drive,..??
I think your motor is Sick, rather than the prop to Big...
Unless of course the Hull has other Problems.....
