Re: 19' wellcraft with evinrude 115 have hardtime plane out
i will run it again next time out , how do you adjust trim and what size impeller is the right one for my engine ? it's a evinrude E115TSLECM 98. thanks
well one thing at a time is best...
go get some BPR decarb fluid...
I wouldnt suggest the seafoam yet for you...there is a fluid you can add to the gas and over a few tanks will help remove carbon deposits( or is supposed to anyway)
then take the boat out with a light load maybe one other person..
when you launch the boat you raise and lower the angle of the motor with a buttom , probably on your throttle control... right?
you probably lower it all the way down till it doesnt go any more ... right?
thats fine....take the boat out preferably on a calm day and get it up on plane..which ever way you can....
make a note of your speed( gps unit or speedomiter is fine) and make a note of your RPMS...
now while going as fast as the boat will go, touch that button on your throttle control and RAISE the motor..
lets say hold it for 2 seconds..and let go and see what the speed and WOT are now..
then hold for another 2 seconds and let go..and monitor the rpms and speed.
if the motor is ACTUALLY moving...which it should be...you SHOULD notice more speed.... continue that until the speed and rpms drop back down.
remember the number of 2 second sessions you did..
then come back and let us know...
what happens is the boat wants the motor all the way down to get up on plane the fastest....then once up on plane the boat will actually go faster if your trim the motor higher....
you ahve the button for trim and tilt on your control ...right?
now depending onthe rpm and speed numbers....we might be able to offer a suggestion about the best choice for a prop.. or at least a place to start...
watch your temperature while doing this ...
do you have a water pressure guage????
if not , next trip into the mechanic have him add one....
it is good and will help you make sure you dont over heat your motor..
g ood luck
bob
