1940 HS 15 Parts
JDusza
Ensign
Working on a HS 15. Bringing it back from the brink. Runs like a beast, but, I have a couple questions.
1 Where can I find an exploded view parts list for this engine?
2 This particular engine does not have a fuel shut-off valve. With the gravity feed system used, I would have expected the unit to have one. So, ... I am looking for a fuel shut-off valve that will fit under the tank.
3 I don't think the fitting at the water exit is the right one. Water sprays all over the handle and the rear side of the engine making EVERYTHING wet. This can't be right. So, ... I a looking for another fitting which will redirect the water, perhaps with tubing or a small hose.
4 Can you tell me how to use the pump and dial on the carburetor? I'm no convinced this particular unit is giving me any benefit.
5 What kind of grease is used in the lower unit?
Thank you for any and all help!
J
