I recently acquired a 1960’s aristocraft nineteen and the lower unit was off and engine cranked but wouldn’t fire. From what I could find from wiring diagrams from the mercruiser manual posted online, it looks like the coil isn’t wired right? Can someone verify this? Brown wire is on positive, black wire to negative and white wire isn’t connected. I believe white is positive, and brown is negative and the black is negative from the distributor? Also the exhaust elbow is missing all of its bolts. Anyone know what size bolt it takes or where I can order them? Needs the gasket too. Thanks in advance everyone
