Hello! This is my first post. I have been working on my 1963 5.5hp Evinrude Fisherman outboard. Added a new spring & pull rope in the starter. We replaced the gaskets & cleaned the carburator. New fuel filter. Replaced fuel pump. We had to use the old float needle(no spring) and screw because the pack I bought had the wrong thread for the carburator. We backed out the top needle 1.5 turns. 1. Do you back out the lower/bottom needle the same amount? It seems to be pumping water fine. Starts and idles, but dies when you throttle. 2.Is this a settings/dial (needle) issue or something else? I am planning on replacing the lower unit oil next. 3.If it's pumping water, I shouldn't need to check the impeller, correct? Thanks ahead for any thoughts or suggestions.
