1965 40hp Evenrude cuts out when put in gear
AustinH
The engine runs great in nutral but when it is put in forward or reverse it cuts out immediately. Please help!!
rolmops
Re: 1965 40hp Evenrude cuts out when put in gear
Hello.<br />Could be a few things.<br />Can you turn the prop by hand when it is in forward or reverse with the engine off and the spark plugs out?
AustinH
The prop will turn only slightly then it catches, and will go no further. Additionally, if i did not have the motor in "lock" position, would that cause that? Also, if the two "clutch coil" wires coming up from the lower unit were reversed, that is, plugged into the incorrect two wires coming down from mid-unit could that cause this problem?<br /><br />One more thing: if the twenty roller bearings were removed from above the pinion gear around that magnitized shaft, what would happen? They fell out when we opened it up and they seem imposible to get back in even with the engine upside down. Thank you for all your help, please respond. The bearings seem to have no purpose other than increasing friction. I wonder why they are there?
rolmops
Sounds like it is the highest time to get yourself a manual and see where that bearing came from.If you want to try to put it back together, all you need to do is get yourself some grease fill the bearing housing with grease and then put everything back inside.
