1966 starcraft hull# 1nz100589005 looking for manual
Re: 1966 starcraft hull# 1nz100589005 looking for manual
Just bought this 66 starcraft and need a manual for the motor or where i can find one
Ayuh,.... Welcome Aboard,.... What motor has it got,..??
GA_Boater
Welcome aboard. Your hull number or HIN is issued by the state of Indiana (INZ) when it was registered as homemade so it won't help getting info about the boat. Like Bondo said - What motor is on her? Then we can help.
salmonrungirl17
It has a 120 i/o mercury from what i know it was called the iron duke the numbers on it are 3308TZ, 4469922 the boat is 18ft aluminum
thumpar
The "Iron Duke" usually refers to the 2.5l that was used a lot in the Fiero and other cars. It is a different motor. The 120 was only used in a car for a couple years in the 60's. You can find the manuals in the adults only sticky.
Ayuh,... Like thumpar says, it's a distant cousin of the Iron Duke, but anyways,...
This is the link to Don'S Adults Only section,...
In there follow the Mercruiser links to the factory manuals,...
You need manuals #1, 'n #2,....
salmonrungirl17
Thanks you i have another boat that really needs some help also
