1969 Johnson 40HP Wiring Rebuild
HighTrim
Re: 1969 Johnson 40HP Wiring Rebuild
Awesome! Now time to enjoy the water ;)
nwcove
did you ever get your hands on a torque wrench???? if not, your first trip on the water may be short lived. proper torque on that nut is crucial! ......a wrench and a 2 foot piece of pvc pipe does not make the cut as a precision tool! :facepalm:
sdepew
Hey guys just got another one of these outboards. My first 1968 40 hp johnson RDS-30A had no GEN and the new one does. But I'm only finding the Voltage regulator. Where and what does the Gen look like and mounted at?
Thanks
lindy46
Looks like a starter, mounted on the front port side of the motor, opposite the starter. Has a belt driven by the flywheel.
Darin bees
Hey Steve, whereabout are you from?
Here is something that will get you close.
As stated, only 1 lead to the cutout, then onto the M terminal. The other black lead direct to the M terminal
I have the same motor same problem had mine running but not well and than it shorted out desperately need that d I agram so I can read it
Darin bees
I think I can figure out how to make that work except mine doesn't have generator or voltage regulator wish I could find a new wire harness is every thing still wired the same I need this running so my girl stops giving me **** for buying this little span boat
Wiring diagram is found at -----mastertechmarine------Or google outboard wiring diagrams.
