hallucitrippin
- Jan 4, 2002
- 7
Ok my brother, father and I have been working on this thing for two days, we've never had it running. First we were getting no fire, after a lot of trouble shooting we found a bad place in the black and white wire that runs from the CDI box to the points. We fially got spark.<br /><br />So here is the new problem. to get to the points we took the flywheel off, then the "distributer cap?"(first time i've seen one of them under a flywheel) under that is what I would call a rotor button. Well of course this wouldn't be held in place with a keyway or anything like it, What it seems to do is turn by a washer like spring that presses against the flywheel when it is torqued down. Anyway, assuming that that is the way it works, I dont know how to set the timing on it, and I think that may be why it is not running(it won't even kick).<br /><br />So I did what anybody that has encountered something like this before would do. I set the #1 piston on top deat center, and pointed the distributer cap to the corresponding wire(which just happened to be the same as lining it up with the key in the crank) Still Nothing. Another strange thing is that when we are cranking it over if I advance the timing I will lose spark. If anyone can help me with this I will be eternally grateful
Thanks
