1971 Gibson houseboat with 318 Chrysler engine and outdrive
Rockyiv
Where can I find parts for this outdrive. It is white in color and is not a Volvo
steelespike
Re: 1971 Gibson houseboat with 318 Chrysler engine and outdrive
It could be an OMC you may be able to identify by part numbers on components or see if you can find pics.Post this at the I/O section. Bearings,seals and universal joint parts may be available at an industrial supply.
Rockyiv
Nope it is a Chrysler out drive. Need the hydrolic shocks that prevent damage if the drive hits anything
Ayuh,.... The Only place I've found is Marysville Marine, in Marysville Mich....
Rockyiv
Thanks but could not find and outdrive parts at Marysville Marine. Had all the engine parts but no outdrive
