FullMetal129
- Aug 8, 2022
- 7
I am looking to replace the gearcase on my '72 Johnson 65. I have the service manual and the only thing that concerns me is that I don't have the gauge to check the shims to set for the pinion. I don't *plan* on replacing anything but the seals and O-rings when I transfer the parts to the new case. It is a relatively low hours engine, fresh water only and gear oil has been replaced regularly. The boat and motor has been in the family since new, so this is largely a sentimental endevor to fix the skeg and a minor dent from a rock strike. There is also value in inspecting the internals to verify all is well.
Of course, the original gauge is unobtainium and the replacements are quite expensive. I am willing to take the driveshaft to a mechanic to have the shims checked, but I'm not sure it is necessary if I don't need any new gears, washers, bearings, etc. Input from experienced mechanics will be appreciated!
Thanks!
Thanks!
