1972evinrude 9 1/2-shuts off at low speeds
rjnreds
I have a 1972 evinrude 9 1/2 short prop.Model(m9222). Cuts out at slow speeds, runs great half throttle and wide open....
bubbakat
Re: 1972evinrude 9 1/2-shuts off at low speeds
What do you mean it cuts out. Does it quit running or does it miss firing and then quits.<br />Has it always done this or is this a new to you motor.<br />If you don't know much about the motors history I would do a compression ck and if both cylinders<br />are close on the compression I would rebuild and clean the carb and check the fuel pump.
rjnreds
Originally posted by rjnreds:<br /> I have a 1972 evinrude 9 1/2 short prop.Model(m9222). Cuts out at slow speeds, runs great half throttle and wide open....
rjnreds
It just shuts off at low speeds. No spit and sputter, just stops running.The motor is new to me.Runs great half throttle and fast speed.Turn down to slow and it stops.
bubbakat
I would clean and rebuild the carbs. Sound like your low idle jet is stopped up.
