1973 65hp merc no fire
00icu692
Have a 1973 merc 65hp , ran last year , this year no power , checked iginition , kill switch , all the basics , have power going to the switch box , but when i turn the key on i have no power to the distributor or the coil , so i order a used switch box and the same thing , is it possible the power switch box i received could be bad too or am i missing something else i can check thanks
The Marine Doctor
Re: 1973 65hp merc no fire
The distributor that you have, does it have 3 wires that run from it to the powerpack?<br /><br />If so...this is where the problem might be.<br /><br />Its more common for the Dist (Trigger) to give out than the powerpack.<br /><br />TMD
00icu692
Thank - you i will check that , since there was no power running from the powerpack to the distributor i thought it might be something different thanks again for your help
JHeheman
On my '71 850 85hp it was the trigger(distributor lower housing). It had intermittant spark. The part is not cheap and is not the easiest thing to change. You'll need a manual.
