1973 Chrysler 707HE 70HP
JHurwitz19
Hello all, I am new to this and just finished restoring the outer shell of a 1962 Lonestar Biscayne Biat. I have moved onto the electrical wiring and motor now. I replaced all of the original wiring one by one, however as I’m a newbie to the marine engines, will a motor that old have charging capabilities of the cranking battery? Should I run a separate power source to utilize for accessories such as a horn, LED running lights, gps/fish finder combo? Any help or advice will be greatly appreciated.
Tassie 1
Of all the bits and pieces you've mentioned the only thing that will be on a lot will be the fishfinder/ chartplotter,
you don't use a horn much at all,
Nav lights when it's poor light or dusk,
l wouldn't consider going out late at night or all night with a 47 yr old Chrysler, specially if in coastal waters,
And l've had 10 or so Chrysler motors, including two 70's
A second battery is always a good thing to have regardless.
JHurwitz19
Thank you Tassie, I will look into obtaining a second battery for the accessories. Then I can use the other one strictly for cranking the motor. Thank you for your input. How long will a battery typically last on a full charge while running a fish finder/chart plotter?
Tassie 1
In the real world l really cannot say how long a fishfinder/chartplotter will last on a single fully charged battery,
There are so many models with many different options
it's a bit of a piece of string question
keeping in mind that most modern electronics will turn off automatically when voltage drops below a certain point,
jerryjerry05
If properly wired? your motor should charge the battery.
New hot battery should last a long time.
Myself I never killed one even fishing all day.
A second one hooked up correctly is a good idea.
JHurwitz19
I wired a second battery and tested the outgoing amps to discover that the motor does in fact charge the battery. Thank you guys for your help!
jerryjerry05
Don't use a deep cycle as a starting battery.
The charging system on most outboards isn't designed to charge them.
It can damage the system.
JHurwitz19
I have a cranking battery in there as my starting battery, then I installed a battery selector switch and the deep cycle battery. The deep cycle battery handles the lights, electronics, etc. Thanks again!
