1974 Chrysler 105 Rough Acceleration
hbryant123
I have notice if i slowly accelerate my boat there is spots where the engine runs rough and sends shakes down the boat then as i accelerate more it clears up and she runs fine! Its like something is off and it hits a funny spot and kinda shakes and sputters, if i leave it in the spot and don't continue to accelerate it clears up. I am wondering what can cause this? it starts great always and cruises good and has good speed.
jerryjerry05
First check the fuel for water.
Then clean the carb.
Install a filter between the carb and the pump.
Reset the air/fuel screws.Start at 1 and 1/8th to 1/4 out.
hbryant123
I have adjusted the screw that is in the end of the carb before, it runs nice at idle and at wot and cruising. I am pretty sure the points were not gapped properly and im not sure on the timing. When i got it running my boat motor knowledge was low!
SkiDad
if your talking about 2000 rpm i think that might be normal - if feel that too if i take off very slow - but 1/2 thottle or punch it and it's not there.
Frank Acampora
Points need to be set at .010 open. The transition point between carburetor low speed circuit and high speed circuit can be a rough running spot. It usually happens around 1500-2000 RPM. The fact that if you leave the engine at the rough spot and it eventually clears points to either carb setting or oil recirculation system.
If your carb is or has been cleaned set the slow speed needles to about 1 turn out. Now take the boat out for a run. After it is warmed up do a full throttle hole shot. If the engine stumbles and runs rough then clears itself and runs well the needles are too rich. Continue hole shots and lean by 1/8 turn in at a time until you get smooth acceleration. HOWEVER: CAUTION. Too lean a setting will cause piston damage. DO NOT lean the needles to less than 3/4 turn out from lightly seated. 7/8 is better.
If the engine sags and then recovers, then picks up and runs well the needles are set too lean. again, richen by 1/8 turn out until it accelerates smoothly.
The oil recirculation system works to improve the idle. At low RPM, fuel puddles in the bypass passages. It can accumulate to the point where a slug will enter a cylinder and cause a misfire. The oil recirculation system burns this fuel in a cylinder BEFORE it becomes enough to cause a misfire.
On the fuel pump side of the engine near the split line are two plates held by four bolts each. these are the oil recirculation system. Remove the plates. You will need to make new gaskets because they are always destroyed in removal. Split the plate halves and clean the screens and orifices.See if that helps.
