1975 Chrysler 45 hp 457HG WOT Only getting 3000 RPM
ewowiugrad02
Hi Everyone,
I have a 1975 Chrysler 45 hp 457HG on a 15ft Chrysler Sport Satellite. When I go into WOT, I am only getting 3000 RPM's. The speedometer is only reading around 5 MPH. It's the battery ignition with the alternator. It idles fine, and there is no hesitation going up throttle in gear. When I get it from mid throttle to WOT, the tach get up to 3106, and that's it. The outboard does not sound like it is at full throttle.
Here's what I have replaced:
A. New Fuel pump and gasket.
B. Two new screens in the fuel recirculation reed plate. The original screens were clogged up.
C. New Screen in the fuel pump filter.
D. New fuel filter.
120PSI on both cylinders. Spark is fine. I made sure the timing is at 30 btdc at wot, per the service manual. The tank is clean. It's a newer 6 gal attwood. The fuel line is not stiff, it's flexible, and I am not seeing trash in the carb bowl. On that note, I cleaned the carb with carb cleaner and compressed air this week. No crud under the needle, and the main jet is spotless. The float is at 13/32'' when hung upside down. I adjusted the throttle cam bar going to the carb, so when it's in WOT, the butterfly is horizontal. The choke butterfly stays at horizontal when not choked, so it's not causing a restriction.
I have owned the boat for the last year and a 1/2. I put the tach on the boat at the beginning of this season. So I know for the last 4-5 times out, that it is constantly only getting up to 3000 at full throttle. The boat is actually under propped. It's got a 10x10 3 blade on it. The Chrysler Service manual says it should have a 10-3/8 x 13-1/2 on it.
The boat will have me, 1 gas tank ,1 battery, and 1 anchor in it. I really don't think I am over weighing it down. Any help figuring out how to get the WOT rpm's back up to 4500-5500 would be greatly appreciated.
Nordin
Is the throttle open up all the way to horisontal?
Then the prop seams to little. You should have a 10 3/8x11 or 10 3/8x12.
With your prop 10x10 it should rev. more then 3000rpm, but very slow speed.
ewowiugrad02
I am going to run the outboard in a garbage can this week, and see what the RPM's are going to be at WOT. The whole idea will be no load of the boat working against the prop. If I am getting 4500-5500 at WOT, then I am going to look at trim, prop, or weight of the boat as the problem. But if it is still at 3000 at WOT, then I don't know where else to look at.
ewowiugrad02
I ended up buying a new 10-3/8 x 11-1/2 prop. I got the boat on the lake last night with the new prop, and I got it up to 4410 rpm's at wot. I was moving along at 21 mph per the speedometer. - I can live with that. The old 10x10 prop was bent up pretty bad on all 3 blades. I think the previous owner hit some rocks, and it bent in the tips of all 3 blades.
