1976 1150 115 hp question about water pump
olsoncsb
I haven't ran my motor in a year or two and I hooked water to it with muffs and it was take water in but not comming out of the pee hole. I checked and blowed the hole out, but it didnt seemed block.what could be causing this and how can I fix it? Any answers would be greatly appreciated
Chris1956
Re: 1976 1150 115 hp question about water pump
Olsoncsb, Those motors have a grating above the anti-ventilation plate, behind the prop. This is the important exit for the water. The "pee" hole can clog easily. If the grating has water exiting, the motor is pumping. At idle the water should be warm, but not hot. Careful not to get your fingers in the prop!
andrewkafp
When did you last change the impeller ? It may have become "Set" with curved vanes from the long sit and is in need of replacement.How long did you run it on the muffs ? They normally take a few minutes for the water passages to fill up before "peeing".<br />It's a good practice to run your motor on muffs 3 or 4 times a year to keep the impeller flexible and wash out any residue in the the water pump housing.
brianmerc
I have this same engine. When water doesn't come out of the pee hole, I just put my mouth over it and blow up into the hole, then afterwards the water starts to come out. Like Chris1956 says, water should also be coming out of the grating on the lower part of the engine and should be warm. The water coming out of the pee hole will be a little cooler. Good luck!
