turtle1173
- Nov 29, 2001
- 437
Hi,<br /><br /> I have been battling trouble with a 1976 55HP Chrysler for a while now. I have replaced the head gasket, thermostat, exhaust gaskets, puddle drain gaskets, fuel pump, and reed valves. The points and condensors were replaced by a mechanic last year. The compression is between 135 and 140 on both cylinders. When I had the head off, the cylinders looked very nice. There was very minimal carbon build up.<br /><br /> The problem I'm having is that the bottom cylinder won't kick in. At lower throttle levels it "tries" but doesn't ever get it. This is a problem that has progressively got worse (i.e. it used to miss for the first couple of minutes after start up but after that the 2nd cylinder would kick in and it would be fine the rest of the day).<br /><br /> This is a one carb engine, so I don't believe that is the problem.<br /><br /> I figure it must be an ignition problem. I have swapped coils before with the same results, so I figure the coil is not bad.<br /><br /> I'm really at the end of my rope. I am trying to take the flywheel off to take another look at the points, etc. and I'm having trouble getting the flywheel off. My mechanic tried to get the flywheel off yesterday for me but broke a bolt on the puller (luckily he got the bolt remnant out with some needle nose pliers). I've got a puller on it right now cranked down with PB Blaster soaking on it.<br /><br /> Does anyone have any other suggestions before I just toss this thing?? Oh, by the way, this Chrysler has the battery type ignition (2 external coils and no CD module).<br /><br /> I thank you for all the help you've given me in times past and hope you will be able to assist again.<br /><br />Thanks,<br /><br />Shane Williams
