stone_holder
 - Jun 4, 2001
 - 12
I have a 1976 70 hp evinrude that will run perfect for the first 5-10 minutes and then if i shut it completely off and then try to restart it idles a little rough and then when i put it in gear it dies if i try to accelerate.If i just leave it at idle speed in gear it will stay running but the moment i give it throttle it will die. I tried changing sparks plugs and got the same results. The compression is fine(130 lbs) in each cylinder. New fuel pump was installed and it's definitely getting fuel to the carbs. My timing at idle speed in gear is 4 degrees BTDC. The spec's call for 3-5 degree's ATDC for the idle but i can't get it there because it will die. I have cleaned the carbs and today i installed new needles and seats but have not tried it yet.Any answers would be greatly appreiciated. Thanks.
