thomasando
- Jan 20, 2013
- 22
Over the Easter long weekend I spent a lot of time in the boat, and started to notice a new issue.
The issue is - shifting the boat into forward gear often results in it taking off - not with a great deal of speed but certainly more than it should have. Normally it shifts into gear at idle but now the revs climb slightly before it engages. This causes a bit of a sudden take off, which can be embarrassing if you're not expecting it.
I also struggle to keep it in gear when trying to move slowly, eg. docking. It slips out at low revs.
Getting it to pop back into neutral often (but not always) requires pulling the throttle in the reverse direction, too (further back than beyond neutral).
The final thing that's happening is, when the boat is coming onto the plane after a hole shot and the load decreases slightly on the motor, the gear seems to slip (I presume this is the dog clutch slipping). This only happens at WOT, if I use slightly less throttle this doesn't seem to occur.
I expect I need to adjust the throw in the gear cable to fix the selection (idle) issue, the keeping it in gear and the grabbing neutral issue. Note that the reverse direction has no problem.
Is there a specific procedure for these motors to follow for this? I searched but didn't find anything specific to the Chrysler, so not sure if that means there's no particular method or that nobody has ever asked it before!
Is fixing the first 3 issues also likely to resolve the slipping as it comes onto the plane? I thought I'd read at some point that a poorly adjusted gear select cable could result in a slipping dog clutch.
