1977 Chrysler 105 owned 20 years
chryslerdon
I have water on my bottom cylinder spark plug,is this a blown head gasket?It has 140lbs of compression on all four cylinders.Second i am looking for a clutch for this motor,Who has one for sale?
ALVIN A
Re: 1977 Chrysler 105 owned 20 years
Chryslerdon,<br /> I had the same problem on my 50 horse force.After running my motor for a while It would start to mis,there was water getting in to the top cylinder. When I did a compression test both cylinders had 120 lbs,but there was a pin hole in the head gasket. <br /> <br /> AL
Terry H
Your first step would be a leakdown test on that cyl and compare to the rest. If you don't have access to that tester pull the head and see what you see. Should be apparent where water enters...<br />just a Thought
chryslerdon
OK ,guys thanks for the info on the head.I am still looking for a source for a shift clutch for a 1977 chrysler 105 (Serial 1057h8h).Does anyone know where to get a good used one or a new one.The local dealer can get it for $143.0UCH
