1977 Chrysler 10hp 100HA exhaust cover specs
Undersquare
Does anyone have torque specs and tightening sequence for the exhaust cover on this motor? I've replaced the 2 gaskets and plate once and its leaking on me. Should i use permatex?
Thanks for reading
tphoyt
Try posting under Force and Chrysler
And you may get an answer
oldboat1
Check for cover warping. Use a piece of glass or a similar hard surface, maybe your table saw. Permatex won't hurt. Torque bolts evenly.
oldboat1
criss-cross circular pattern starting from the inside. Half torque value on the first pass, full torque on the second pass.
