wheelers4life
- Jun 10, 2015
- 70
I have a 1978 Johnson 115ETL78C outboard. this is a old boat a bought and replaced the gears and the ignition switch in the remote control. I took it out a few days ago and it would not go into foward very good. si pulled the cover off and tried to adjust the shift cable a little at a time until it would go into foward and reverse easy then all the sudden It would not do anything. I got it home pulled the remote apart and the pin that connects the shift cable was out. I put the pin back in and took it out today. put it in reverse off the trailer. put it in foward and dang nothing took it apart and the pin is out again. what could be causing this problem. Thanks old picture but you can see the pin just slides in and out easy
