1978 Merc v6 ignition trouble
wpannkuk
I have a 1978 merc 175 hp. It has not been run for a couple of years. I have tried to start it and cannot get it to fire. It appears that there is no spark. Does anyone have any suggestions on the source of the problem or a means to figure out the problem?<br /><br />Wpannkuk
The Marine Doctor
Re: 1978 Merc v6 ignition trouble
There are a number of reasons why it may not have spark.<br /><br />First check battery connections..see if they are tight and that you have atleast 12.6 volts at the battery.<br /><br /> Ign switch..switchboxes..stator..trigger are the likely candidates.<br /><br />If you d/c the yellow and black wire at the switchboxes, you can take the ign switch out of the equation.<br /><br />It is rare for the trigger to take out all 6 cyls. <---this can be more or less ruled out.<br /><br />That leaves us with 2 alternatives. Stator or Switchboxes.<br /><br />Without a DVA tester, you will be guessing at the problem.<br /><br /> :( <br /><br />Wish I could be of more help.<br /><br />TMD
