ranger115blue
- Mar 2, 2003
- 13
My lower unit was leaking. I found out that is is crack. It is a 1979 Mercury 115 Outboard, I also have a 1965 65 Hp Mercury Outboard the gear cases look identical. Would these interchange. I would have to change the prop shaft and gears because the reverse is out of the 65 horse. I removed the first prop shaft retainer nut, I remove the square retainer pin but I broke the 1/2 drive ratchet trying to remove the prop shaft retainer nut. Could I weld the cracked gear case and it be strong enough? it is cracked from the drain plug around the front of the gear case and down the other side. Thanks for any help, Terry
