1979 20 hp chrysler manual start convert to electric srart
Jb4507hd
I am wanting to convert my manual start motor to electric start model # 202h9k. Is this possible and cost efficient? What parts would I need? Thanks in advance.
S.A. Baker
I can see why some would want to. I spent 42 years as a powersports tech yanking on snowmobile and outboard recoil starters. BOTH of my shoulders are shot. I can barely start my 1958 3 horse Johnson!
Nordin
Jb4507hd Of course you need a starter AND you need the bracket who the starter is mounted in. The starter solenoid and it will be mounted on the bracket just under the electrical terminal. Wireharness and keyswitch.
Check out Ebay, Craiglist and that kind of sites.
Starters and brackets from Chrysler 25 and 30Hp 1973 - later will fit and the "new" 35Hp from 1976 - later.
20Hp will fit from 1978 and later.
These enginefamily was introduced in 1973 as 25 and 30Hp. The 35Hp came 1976.
AND REMEMBER early 20Hp and early 35Hp will NOT fit. They are completly different engines then yours.
all it takes is cash.
cash to buy all the obsolete parts and install.
or add cash to the pile you get when you sell your manual start motor, and buy an electric start.
as indicated above, start looking on ebay and craigslist.
jerryjerry05
Good luck finding parts.
​You'll need flywheel, starter solenoid and bracket.
Probably the wiring harness and cables and , and, and.
Just buy an electric start.
Nordin
jerryjerry The flywheel will not need to be replaced. It will fit for the starter, I know because I have converted a couple of 25 and 30Hp .
Jb4507hd Try to find a no running (bad head or LU) 25 or 30Hp. The engines with battery ign.system was always equiped with electric start .
