chuckharwell
- Aug 3, 2003
- 1
The details:<br />129 compression on 3 of 4 cyl.4th I couldnt get to./I pulled the plugs and the top 2 are clean but the bottom two were smokey./It runs fine out of the water but when I put it in the water it started and died then wouldnt restart. I noticed water leaking around the 3rd sparkplug. This is a new boat for me and I am not sure what to do next. I recently overheated the motor due to a bad impeller which I just replaced. The compression is consistent still so I am not sure if the headgasket is blown, the block is cracked or what?? Thanks for the help
