1979 chrysler 6hp
gacatfishking
I have a 1979 6hp chrysler outboard that when i crank it will run for about 30 seconds then die any ideas what could be wrong and how to fix it would be appreciated :confused:
dfb
Re: 1979 chrysler 6hp
could be air leak in fuel system. Replacing the fuel line/primer bulb might fix.
turtle1173
Chip,<br /><br /> How long has it been since you ran the engine previously? It could be the fuel pump but certainly seems to be "fuel related."<br /><br />Shane
scotiany
In addition to the above replies, you can get the carb rebuild and fuel pump kits at NAPA. They're not expensive.
