1979 Chrysler 72H9R 7.5hp outboard questions
Bakon2
Ok, I sold my big boat and got a good flat bottom john boat for the river with a 1979 7.5 hp Chrysler. I replaced the fuel lines because they were dry rotted...got them hooked back up and the motor would start but only run on full choke...and then I had to open and close it to keep it running. I am sure the fuel was not the best as it was left over from last year. The tank is the OEM metal tank. I considered replacing the tank and probably should. The other problem I am having is the primer bulb will get just a bit firm but it seems to not expand back all the way, like there is a vacuum or something. Any ideas?
Bakon2
alrighty....update
​replaced the oem fuel tank with a plastic. put in new fuel, changed the connection going into the tank, started up the motor with full choke then let it run a few minutes. took the cover off, turn off the choke and adjusted the idle...runs like a champ. I let it run for five mins or so and then did a questionable thing. I went inside and got the wife and we pushed the boat into the river (no, its ok, it runs through our front yard) got the 2 little ones and up river we went. But it ran very smooth.
jerryjerry05
Needing to choke to keep running is a sign of a bad fuel pump.
​Or a pump needing to be looked at.
Ethanol is screwing up a lot of hoses and connectors.
Install a filter G-2 or G-3 maybe G-12 Fram from Wallyworld.
Install it between the pump and the carb.
Bakon2
Thanks for the advise...but here in the great state of Wisconsin...we are the land of Beer, Brauts, Cheese and E0 ethanol free outboard fuel :)
