1980 Starcraft Questar Wiring Diagram
ebarber
Hello all!
I bought an old 1980 Starcraft Questar 191b with the Mercruiser I/O 140 in it.
I'm working on getting it running and have some electrical issues.
One of my friends who is a great mechanic wanted me to try to find something online for the electrical wiring.
I was wondering if anyone had a wiring diagram handy that they might be able to share for it.
The last guy who owned the boat hacked a lot of stuff up.
I had it running then lost all power to the helm last week.
Im going to need to do some serious work on the electrical.
Thanks for any help!
Eric
welcome aboard
wiring diagram for the whole boat - probably never existed (they usually dont)
wiring diagram for the motor - in the manual.
marine wiring colors are standard. from the color of the wires, you can pretty much tell where every wire goes
BlackGroundNegative / Neutral Main Return
Blue-StripeTilt up and or trim outTilt and or trim circuits
BrownAlternator Charge LightGenerator Terminal or Alternator Auxiliary Terminal to Regulator
Generator ArmatureGenerator Armature to Regulator
PumpsCircuit Breaker or Switch to Pumps
Brown w/YellowBilge BlowersCircuit Breaker or Switch to Blower
Dark BlueCabin & InstrumentCircuit Breaker or Switch to Lights
Green or Green w/Yellow StripeBonding SystemGrounding Wires (if insulated)
Green StripeTilt down and/or trim inTilt and or trim circuits
GreyNavigation LightsCircuit Breaker or Switch to Lights
TachometerTachometer Sender to Gauge
Lt. BlueOil PressureOil Pressure Sender to Gauge
OrangeAccessory FeedAmmeter to Alternator or Generator
Common FeedDistribution Panel to Accessory Switch
FeedAccessory Circuit Breakers or Switches
PinkFuel GaugeFuel Gauge Sender to Gauge
PurpleIgnitionIgnition Switch to Coil & Electrical Instrument
Instrument FeedDistribution Panel Electrical Instruments
RedInstrument FeedDistribution Panel to Electrical Instruments
Power FeedsPositive Main Power (particularly un-fused)
TanWater temperatureWater temperature sender to gauge
YellowGenerator FieldGenerator to Regulator Field Terminal
Yellow w/RedStarting CircuitStarting Switch to Solenoid
COLOR ITEM USE
