1980s force 85 horse.no spark on third cylinder
rickkz
im new to this but i can turn a wrench ..cylender 1 and 2 have spark ..the third is dead .i replaced the coil and still no spark,,could any one help with info,thanks
jerryjerry05
Re: 1980s force 85 horse.no spark on third cylinder
Start with changing the bottom coil for the top.
That makes no change.
Then switch CD's.
Take pics cause there is no easy way to figure the mess out!!.
Write down the color codes,no easy way to figure out the mess!!
Compression test?
rickkz
Thanks for the reply.ive unpluged the coils from the cds and switched them..the spark problem went to what ever coil i pluged into the cdi that had only one coil.so the the second cdi i assume was bad..ive put a used cdi on and still no spark..ive got the wireing diagram and it appears im wired right..............could the triger be bad but still alow the first cdi to frier and not the second?????or should i go over this guys spliceing job and put a new cd on thanks
