could someone help. when I start the motor I turn the enrichener full on the motor starts an the and the enrichener kicks almost to off and the motor dies. Now I have to pull the cord about 20 times because it floods. After the motor warms up it runs fine although when I go from 1/2 throttle to the lowest speed it chokes and almost stalls. The carb was worked on a while ago the compression is 130 lbs on both cylinders. Also would someone know the low speed jet setup(turns out).I have know manual.
