1981 Formula One Stringers and Transom rebuild - few questions
antleo
Stripped to the keel and all the big stuff cleaned out. Not sure if I should wash it out or try and get it to dry out and shop vac it..
Scherfz1
You are gonna wanna ditch the flapper wheels for 36grit resin sanding disc’s and I washed my hull out with water after trying to vacuum up everything I could.... the dust goes and gets everywhere....
kcassells
I had no issues withhttps://www.amazon.com/10-Pack-Density-Zirconia-Grinding/dp/B079Q4T2JY/ref=sr_1_7?hvadid=78615134470790&hvbmt=be&hvdev=c&hvqmt=e&keywords=sanding+discs+36+grit&qid=1563575183&rnid=2941120011&s=industrial&sr=1-7
these discs.
Also bought in 6" that fit my 4" grinder. Cleared a nice path.
