1981 Mercruiser 120 cutting out
alldodge
Yes, IF the gears have not been changed inside, most likely not, but anything can happen. Easy to check, put in gear, mark drive and prop, then rotate drive shaft end 10 times counting lower. Should be a bit less the 5 on the lower
