I tested resistance between ground and black and yellow wire starting at switch and working way back toward difference connections on motor. Found a not so good connection on a black and yellow wire on harness between power packs. While testing I found an orange wire to ignition coil loose also. Corrected both and engine turns off with key like suppose to.
Thank you all who helps us out
