1982 Chrysler 3.5HP 32H2E JET ASSEMBLY Broken Need Replacement, HELP!
LinBruce
Hi everyone!
I have a 1982 Chrysler 3.5HP trolling motor, model 32H2E from a garage sale. I was cleaning up the Carburetor and accidentally broke JET ASSEMBLY while screwing it back in( Item 15 in diagram) It broke into half, one half stuck inside the unit, and i think i can take it out. But the Real problem is the Jet Assembly is sold out everywhere! Anyone know if any substitute out there? Thank you!
SEAF10096 1 F10096 - JET-.039
LinBruce
anyone? I called around many marine repair stores, no one carries this part.
Alumarine
You might have better luck if you posted this in the Force / Chrysler forum although maybe not.
It's not really an electrical problem.
You can get a mod to move it for you.
jerryjerry05
Try Googling: antique outboard, outboard salvage,.
mastertechmarine they work and sell parts for older outboards.
F521061-4
this is for a whole carb. There are 2 listed (ebay) same seller.
Is this a tillotson carburetor ?----Fairly common item on Tecumseh snowblower / lawnmower engines.----Take carburetor and broken part to a small engine shop.
jerryjerry05
Oh yea, Gardner parts might have something you can use??
Find a show room and take your carb in??
LinBruce
Thank you guys!
I just sent an email to Franz Marine, and looked at these recommended websites, not much luck. I will check for my local small engine shops, thank you all again! Will update this if I found something.
