1983 150 hp
Painterx
Is there a replacement for the temp sensor on the heads.can it be bypassed? Or is there another way
schematic
Re: 1983 150 hp
You wouldn't want to bypass them, as you would lose overheat warnings. Whats wrong with yours? I know they are expensive. If you google around you can probably find a generic snap disc thermostat that will fit the bore for cheap.
emdsapmgr
Re: 1983 150 hp
Bombardier has discontinued this temp switch. 386686. A number of Bombardier dealers across the US still have new stock on that part. This particular dealer shows 3 in stock: AHLSTRAND MARINE CO, MUNDELEIN, IL, 60060. Phone (847) 949-8899
