1983/84 Force 85 Ignition key
Trophy83
The correct ignition switch is available $69. Can I use one of the cheap $20 ones instead? This is a total budget build and anywhere I can save $50 is a win for the project. TIA
jerryjerry05
Take the boat to any Mercury dealer.
The Force/Chrysler ignition switch only had 5 different keys.
Usually the dealer has a selection and most cost about $5
Yes if the ignition has the same amount of connections the $20 will work.
