NICKSCHMID
- Jul 18, 2019
- 5
Sorry this is a long post. I have 1983 Johnson 50 BELCTA I took in on a trade and found out the power head was replaced with a 1985 power head. When I first started it up it had a misfire and was running rich. So I put new plugs in and rebuilt the carbs. So I started it up and it was still misfiring and but now it seemed like it was running lean. So I messed with carb some more and start it back up and the engine ran away on me. So I found out I had an air leak at bottom crank seal. So I take the whole engine apart and resealed it. So I get it back together and ran it no misfire and the idle was real low rpms so I tried adjusting it and nothing would happen. So I gave up on for a week and I came back to it and start it up and it started misfiring again. So I put spark plug wires started it up and still misfiring. So I got a spark tester and a peak voltage adapter and set the spark tester to 7/16 gap it was a weak spark on both cylinders. So I check the stator and the voltage was good. So I check voltage to the coils from the power pack and both were real low. So I thought it was a power pack thinking there is no way for both coils to be bad. So I replaced the power pack and started it up and it still had a misfire. I checked the power from the power pack to the coils and it still reads low voltage. Seems like anything I do to this engine it doesn’t do anything to it. Should I try new coils? I’m at a loss right now and getting tired throwing money in to it. Has anyone else had any problems like this. Any input would be great thanks in advance.
