83 skeeter
- Jul 4, 2003
- 3
I have a 1983 skeeter ss1 with a Mercury 3 cylinder 70hp outboard. I replaced the water pump last month and let the boat sit in the garage after running it several differnt times, until last night. I connected a known good battery to the engine and the only thing that happened was that the starter began to run but not engage. The key switch will not operate the choke and I have no dash lights. I connected a test light and got power readings on what should have been grounds. I checked all fuses and found none blown.Any ideas?
