1984 85HP Force starter solenoid gets stuck
Pells
Most times when trying to start my engine the solenoid sticks and continues to crank the starter even if the motor is running. i must remove the battery cable to stop this condition. If i put the key to run position and jump the solenoid with a screw driver it runs fine and then i can shut it off with the key. I just replaced the solenoid a few weeks back. could it be defective or is there another problem.
Thanks Chris
The Force power
Disconnect the cable between the solenoid & starter, turn key like normal
Now check with volt-meter if you still have power going through the solenoid
IF..yes it could be two things; one faulty solenoid OR two Faulty ignition-switch (this can be verified by checking for voltage in the (small) power wire on the solenoid)
jerryjerry05
That sounds like the key/ignition is sticking??
Unhook the battery first.
Spray WD-40 in the ignition switch.
Activate the switch, a few times and then spray again.
Then hook up the hose and then try to start.
