1984 DT50 running on one cyl.
Millwright1916
I will try to break this down in order to let you know everything I have tested.
-Compression 105 top
105 bottom
-Timing On as far as I tell running on one cyl.
-Carbs cleaned and checked. Fuel is getting to the bottom cyl.
-Spark This is where it gets a little ify. Top cyl has loads of spark as one would expect being the cyl thats running. The bottom also has good spark however, this is what is strange. When I was checking the timing. with the amp probe for the light on cyl #1 coil lead, the RPM reading was at 4200. With the engine still running I put the amp probe on the coil #2 lead, It was at half the RPM 2100. Now is it feasible that this system is a wasted spark type and the bottom cyl is getting the wasted spark only? Would this be controlled by the CDI?
Thanks for any help as I am at a near loss.
Dale:eek:
