1984 Dt85 Suzuki....HELP
bendro
Can not get it to WOT.Rebuilt carbs,cleaned tank,new fuel pump,new plugs,new bulb,checked timing and compression and installed fuel/water seperator and checked the exhaust.The only thing I have not changed is the fuel connector.Any ideas?Suggestions?Dynamite? Idles great and revs up great however when it is under a load I get about 12-1500 rpms.
James R
Re: 1984 Dt85 Suzuki....HELP
You have done a lot of work but did you check the compressions.
