Doubledame
- Jul 22, 2016
- 10
Take a look at the video and you'll see the pulsating issue I'm talking about. I've worked on tons of these and I've been messing with this one for a bit and it's driving me nuts. Curious if anyone knows what might be causing this. When I pull the hood off it improved and it doesn't pulsate as bad and can get it up to higher RPM before the pulsating kicks in. I did some research on this and found some suggestion that it could be the exhaust housing gasket. Before I go that far I thought I'd check with forum folks.
I've pulled and gone through all the basics...pulled the carb & cleaned meticulously multiple times, excellent compression, spark is great, good gas.
Thank you if you can help!!
DJN
DJN
